Truma c6000
1 20 4
fabgar
fabgar
19/06/2011 37
Inserito il 19/02/2018 alle: 23:59:57
Ciao, ho la truma c6000 in blocco...
i lampeggi della luce rossa dell’errore sono :
breve, breve, lungo, breve, lungo, lungo, lungo e breve... qualcuno sa a che problema corrisponde?
renzo07
renzo07
Inserito il 20/02/2018 alle: 10:30:48
In risposta al messaggio di fabgar del 19/02/2018 alle 23:59:57
Ciao, ho la truma c6000 in blocco... i lampeggi della luce rossa dell’errore sono : breve, breve, lungo, breve, lungo, lungo, lungo e breve... qualcuno sa a che problema corrisponde? grazie
L'ho solo in inglese, il codice e' il 46.
Renzo.
46 s,s,l,s,l,l,l,s
Error:
1) Control panel Combi or power selector switch Combi E defective
2) Combustion air motor or circulating air motor defective
3) Battery earth to the minus terminal Combi defective
Error information
1) Control panel or control panel cable defective
- Power selector switch Combi E or control panel connection cable defective
2) Combustion air motor defective
- Cable harness defective
- Electronics defective (paint spray in control panel socket)
- Internal connection between the (+) carbon brushes and/or circulating air motor and circulating air motor casing via carbon dust
3) Earth connection from the power supply is missing
1st action
1) Replace Combi control panel /or cable
- Replace power selector switch Combi E and or control unit connecting cable
2) Replace circulating air motor
3) Check earth connection (ground cable) of power supply
2nd action
- Check supply line of combustion air motor  - black cable for short circuit to ground or red cable for interruption
- Replace cable harness
- (If cable harness not damaged, replace combustion air motor)
3rd action
Check electronic PCB for paint spray in control panel socket (replace electronic PCB)
𝓡𝓮𝓷𝔃𝓸
fabgar
fabgar
19/06/2011 37
Inserito il 20/02/2018 alle: 16:55:03
Grazie mille....
Felippe
Felippe
19/02/2018 1
Inserito il 20/02/2018 alle: 18:53:59
In risposta al messaggio di renzo07 del 20/02/2018 alle 10:30:48
L'ho solo in inglese, il codice e' il 46. Ciao, Renzo. 46 s,s,l,s,l,l,l,s  Error: 1) Control panel Combi or power selector switch Combi E defective 2) Combustion air motor or circulating air motor defective 3) Battery
earth to the minus terminal Combi defective Error information 1) Control panel or control panel cable defective - Power selector switch Combi E or control panel connection cable defective 2) Combustion air motor defective - Cable harness defective - Electronics defective (paint spray in control panel socket) - Internal connection between the (+) carbon brushes and/or circulating air motor and circulating air motor casing via carbon dust 3) Earth connection from the power supply is missing 1st action 1) Replace Combi control panel /or cable - Replace power selector switch Combi E and or control unit connecting cable 2) Replace circulating air motor 3) Check earth connection (ground cable) of power supply 2nd action - Check supply line of combustion air motor  - black cable for short circuit to ground or red cable for interruption - Replace cable harness - (If cable harness not damaged, replace combustion air motor) 3rd action Check electronic PCB for paint spray in control panel socket (replace electronic PCB)
ciao,
pure io ho la truma 6000 e ho avuto un problema simile.
Ho saputo che quel modello ha problemi se la scheda madre è la numero 1,43 o 1,44. se va in blocco piu di 5 volte non si riavvia piu'. io per fortuna ho la 1,60.
Cmq a me è bastato sostituire il secumotion
zioteo
zioteo
04/06/2020 9
Inserito il 25/10/2021 alle: 19:02:48
Ciao Scusami ho lo stesso identico problema come hai risolto ? e da una foto che ho fatto senza smontare vedo la sigla 1.60 quindi presumo che sia quella che hai tu. grazie
Zioteo
Modificato da zioteo il 25/10/2021 alle 19:04:37
