http://i63.tinypic.com/1zmc8br.jpg
http://i63.tinypic.com/16axu6o.jpg
http://i66.tinypic.com/fwonkk.jpg
http://i64.tinypic.com/t4xkwg.jpg
http://www.lpgnorge.no/stasjonsoversikt/
http://www.mylpg.eu/
http://www.deliapaolo.it/componenti-per-impianti-gpl-e-metano/2515-raccordo-autogas-carico-bombole-attacco-ita...
https://www.google.com/maps/d/viewer?ll=61.354614000000005%2C15.46875&spn=47.508124%2C120.058594&hl=it&msa=0&z=3&ie=UTF8&mid=1CjBWao3nXeS2J_bJP5iI3e1SuyU
http://www.camping.se/en/Campingse-International/
http://www.abtour.it/ftp/areesosta_files/aree-sosta-europa.pdf
http://raavallar.nordiccamping.se
http://www.sjostugan.com
http://www.isaberg.com
http://www.villabjorkhagen.se
http://nordiccamping.se/vara-anlaggningar/glyttinge-camping/
http://www.norrkopingscamping.se/
http://www.eklundsnas.se/
www.angbycamping.se
http://www.fyrishov.se/
http://www.strandbaden-arsunda.com/
http://www.ljusneforscamping.se
http://www.stenohavsbad.se
http://www.sundsvallscamping.se/
http://www.camping.se/en/campingar/3147/Nordmaling-Rodviken/
http://firstcamp.se/umea/
http://www.skellefteåcamping.se
http://www.byskehavsbad.se
http://sikforscamping.se/
http://firstcamp.se/lulea/
http://www.bodenscamping.se/
http://www.kukkolaforsen.se
http://www.camping.se/en/Campingse-International/campings/3137/Pajala-Camping/
http://www.storasjofallet.com/en/
http://www.camping.se/en/Campingse-International/campings/3160/Bjorklidens-Camping/
https://sv.wikipedia.org/wiki/Vindskydd
https://www.youtube.com/watch?v=XWRQaOrYlw0
http://www.camperclublagranda.it/index.php?id=4010
http://turistipercaso.it/norvegia/62166/a-capo-nord-in-camper.html?page=5
In risposta al messaggio di danyducato del 18/11/2016 alle 00:02:38
Grazie Mille La mia idea infatti per il carico era anche quella di utilizzare un recipiente tipo cassetta metterci la neve e tramite un imbuto riempire le taniche da 20 litri io sul mezzo che ho voglio utilizzare solo tanicheda 20 lt quelle alimentari cosi da poterle riempire all occorrenza e sopratutto utili e comode anche per la neve cosi anche in sosta mentre dormo posso produrre acqua ,Per la doccia stesso sistema no la doccia portatile che inserisco nella tanica , acqua ovviamente la scaldo con gli scalda acqua a 12 volt che vengono utilizzati per far bollire l acqua nella caraffa. ho già provato che in 20 min portano l acqua a 60 gradi ... Quindi diciamo che questo problema lo posso risolvere cosi La cosa che mi spaventa e lo svuotare il wc (cassetta) e le acque grigie sempre tanica , ho optato per questo sistema cosi non congela nulla e ho la possibilità di fare acqua o scaricare acqua anche senza andare con il camper . Per il riscaldamento sto optando per la soluzione solo webasto e una stufa a gas o paraffina liquida per l emergenza ovviamente anche sacco a pelo da -15 cosi anche in emergenza posso stare al caldo . La mia ulteriore domanda e` il motore come si comporta a quelle temperature avete avuto problemi ?Io pensavo di installare un telo tipo quello oscurate ignifugo sotto e sopra per la notte cosi da tenere più caldo possibile il motore anche se poco meglio che niente .... Ma il gasolio quindi non lo additavate?utilizzavate quello locale senza problemi di congelamento ???
Quindi come riscaldamento del camper hai solo il Webasto? Quale? 3900? 5500?
In risposta al messaggio di IZ4DJI del 18/11/2016 alle 18:10:07
Quindi come riscaldamento del camper hai solo il Webasto? Quale? 3900? 5500? Invece di stufa a paraffina, io farei montare un Webasto Thermotop sul motore, così hai comunque due sistemi differenti, e lo puoi usare ancheper avviare il motore gia in temperatura, ma lo puoi tenere acceso anche in viaggio per avere sempre l'acqua motore a una temperatura alta. Cio serve anche per potere mantenere ben scongelati i vetri, che con certe temperature puo essere un problema in viaggio. Poi con il Thermotop in funzione esce dalle bocchette del cruscotto aria veramente molto calda e quindi si sta bene in viaggio ma si puo usare anche in sosta. Quest'estate alle Isole Shetland (tutt'altro clima ma il riscaldamenteo si usa) ho avuto la Combi in blocco e con il Thermotop abbiamo supplito benssimo. Altra cosa che mi porterei, un generatore a benzina, abbastanza grosso, sui 2Kw sia per farlo andare quando si sosta isolati e senza corrente, ma anche come eventuale emergenza per potere azionare un termoventilatore a 220 (terza opzione di emergenza). Anche il webasto, mangia tantissima corrente e quindi o ci si collega a 220 o serve il generatore. La stufa a paraffina la eviterei perchè dovresti portarti una bella scorta di carburante, e poi mangia l'aria, e vedo l'uso di un carburante liquido dentro un camper molto pericoloso per gli incendi. Quando facevo alinismo e si dormiva in tenda anche a -25 oltre i 2mila metri, nella neve, per sciogliere la neve per cucinare, era un delirio, messa sul fornelletto era piu quella che evapora che l'acqua che rimane, per farsi una minestra o un the caldo serviva una montagna di neve. Da sola non si scioglieva perchè nella tenda era comunque sempre parecchi gradi sottozero. Per l'acqua, non ho capito bene come sei attrezzato, ma se ho capito hai due taniche interne, una per l'acqua pulita con pompa immersione e una seconda per recupero delle grigie. E' un sistema che unavano gli Hymer di 30 anni fa, ma penso che in quei climi sia la cosa piu pratica così con una tanica puoi andare a prendere acqua anche in un bar o altro. Per la cassetta WC ho trovato uno zaino dove ci sta perfetta, capitato a volte di usarlo per andarla a svuotare nei bagni di un area di servizio o supermercato, o bagni pubblici presidiati, dove vedono uno con lo zaino e nessuno dice nulla, se entri con una cassetta ti sparano . Quando sei chiuso nel gabinetto, poi nessuno vede nulla Tommaso IZ4DJI www.iz4dji.it
Tom, al liceo non ti hanno insegnato che a 2000 metri l'acqua evapora più facilmente che a livello del mare ?
In risposta al messaggio di danyducato del 18/11/2016 alle 23:06:39
@annapasqua SI infatti e un viaggio diverso ... io infatti voglio togliere il superfluo anche perche poi il mio e un mezzo con tetto medio non alto come il vostro quindi anche meno soggetto al vento che da quanto ho capitodal vostro diario e una cosa spaventosa e muove il camper anche con i chiodi .... Ma in quel caso cosa avete fatto io ho anche dietro una sacca con verricello portatile e fasce da 4 t da tiro in oltre un jackup da fuoristrada
si il vento puo' essere un problema, anche perche' in genere non e' mai solo.
In risposta al messaggio di mtravel del 18/11/2016 alle 18:28:58
Tom, al liceo non ti hanno insegnato che a 2000 metri l'acqua evapora più facilmente che a livello del mare ? Dai, scherzo, Max p.s. ammiro quelli come Anna e Barbabianca ma lassù in camper d'inverno non ci penso proprio.Sarò poco poetico ma lo vedo come un viaggio fly&drive (bungalows/pensioni/robuer) piuttosto che con un mezzo dall'affidabilità intrinseca tutta da dimostrare. Poi che si possa fare ci sta.
Al liceo avevo tante cose piu interessanti da fare che studiare ma qualcosa sulla evaporazione in quota mi sa che qualcuno mi aveva detto .
