quote:Risposta al messaggio di Willy93 inserito in data 21/09/2014 23:54:25 (Visualizza messaggio in nuova finestra)direi che non dovresti avere alcun problema. Ti incollo alcune info dal PRODUTTORE: Specifications Nominal Voltage 4, 6 & 12 Volts Design Life 5 Years Operating Temperature -20 °C to 50 °C (Recommended) Grid alloy Calcium / Tin lead alloy Plates Flat Pasted Separator Absorbant Glass Mat Active material High purity lead Case and cover ABS (VO on request) Charge Voltage Float 2.27 - 2.30 VPC @20 °C Cycliing 2.4 @20 °C Max. 2.4 VPC Max ripple 0.05C (A) Electrolyte Sulphuric acid Low impurity Venting Valve EPDM Rubber 1.5 to 2 psi (10.5 - 14 KPa) release pressure. Resealing at 1 psi (7 KPa) Terminal Various types Epoxy sealed by extended mechanical paths Torque setting The recommended torque value for all screw types is 5-7 Nm Cables Insulated cables / connectors supplied on request www.susezzapasa.it
