eberspacher d2 airtronic aiutooo!
1 20 1
redyredy
redyredy
01/05/2013 2
Inserito il 01/05/2013 alle: 21:40:51
dopo un inverno con finzionamento regolare, si e' rotto il tubo di alimentazione (prontamente sostituito) e poi non ha funzionato piu'...[:(][:(][:(] da allora mi da codice errore f017 come posso risolverlo? grazie a tutti redyredy
salomogi
salomogi
20/06/2005 1428
Inserito il 03/05/2013 alle: 17:37:05
dal manuale si desume quanto segue: F 017 Overheating The hardware threshold value for the overheating sensor has been exceeded, because the control box failed to recognise the fault code 012 or 013 –> the control box is locked. If the heater is switched on again, the fault code 015 is displayed F 012 Overheating at the overheating sensor Overheating sensor has detected an excessive temperature. •Check hot air lines for clogging --> eliminate blockage •Sum of partial guide numbers of air conveying parts too large --> check air line, re-route if necessary. For partial guide numbers see accessory parts catalogue. •Check overheating sensor, diagram and values table see page 28, if OK, --> measure fuel quantity, see page 32. F013 Overheating at the flame sensor Flame sensor reports an excessive temperature at heat exchanger. •Check hot air lines for clogging --> eliminate blockage •Sum of partial guide numbers of air conveying parts too large --> check air line, re-route if necessary. For partial guide numbers see accessory parts catalogue. •Check flame sensor, if OK, --> check overheating sensor. If overheating sensor defect, --> replace combi-sensor. If overheating sensor OK, --> measure fuel quantity, see page 32. Diagram and values table for flame sensor and overheating sensor see page 28. Ciao gigi
Oggi alle 06:50
Ieri alle: 21:23
Ieri alle: 20:21
Ieri alle: 19:13
Ieri alle: 17:08
Ieri alle: 14:15
Ieri alle: 11:34
Concerto San Siro Luglio
franci700
Ieri alle: 09:55
Arca America H745
Droams
10/11/26 - 17:33
Lavori in corso
